Results 1 to 3 of 3
Thread: trying to read my error codes
  1. Default trying to read my error codes
    Hi guys
    I'm trying to read the fault codes via the paper clip method .
    I've got four long flashes followed by 6 short flashes...
    so does that mean 46 and is that something about rearbanks running too lean on fuel?
    also it keeps repeating the same code so I assume it only gives one error at a time or am I doing something wrong as I know there should be a few more errors.
    any help would be appreciated
    Code 46: rear fuel metering system. The SM says to check the fuel pressure and check for restrictions.
    If always the same error is shown there's only one error stored. What other errors are you expecting?
    Now you have read it and confirmed it's the only code, you can reset and see if it returns or was a glitch..... Most reset first then have to wonder what the issue might have been!
