The oil will have enough surface tension to get oil on the piston rings and walls. You can also help with an air gun by blowing into the spark plug hole after you filled some oil in. It will splash around on the cylinder wall. That idea is maybe the best, since you dont need to have the pistons in vertical position.  I just got out of the bed and had this idea....LOL
