hi Kaz,
yes the terminal in the AT mating connector felt loose compare to the ones beside it, felt like a spring had gone soft and didn't want to grip on a test pin.
touch wood, it's all still behaving as it should, and it's only done that since i replaced the actual crimped terminal in the mating connector.
the fault, as far as i could determine, was only caused when braking and going over a bump/manhole cover in the road... i learned where the fault was likely to occur on my work commute.... and learnt to avoid them.. not i'm hunting them out, to confirm the cure..... lol!
