Results 1 to 10 of 10
Thread: Steering rack
  1. Default Steering rack
    I've been told by my importer that the NSX has excessive play in the Power steering rack.
  2. Default
    Depending on where the play is, it might be repairable. I won't promise it would be straightforward - few places over here specialise in that sort of thing and the more common route is to send the rack to the states where refurbs are more common - but it can be done. IIRC my NSX had some play in the rack corrected a while back, but I don't recall all the details.
    However, there's also an EPS steering rack for sale in the "For Sale" forum - take a look.
    the most complete repair in USA is via D1guy... http://www.nsxprime.com/forum/showth...NSXs-By-D1-Guy .... http://nsxrackrepair.com/
    Kaz has mentioned a Japanese vendor (afraid i can't remember the name) with the correct test equipment/jig and not sure on the pricings (so not a whole lot of help either way!)
    so there you have it, shiny new from Honda (sit down before they tell you the price) D1guy in the US of A, again, be seated, and the Land of the Rising Sun, i suspect seating is also required, but i think I remember it was more reasonable !
    Jul 2008
    Nr Watford, Hertfordshire
    Are you buying the car from the importer directly including taxes etc or are they simply handling the shipping of a car you've already purchased and registering and MOT'ing for you? If its the first scenario there aren't they responsible?
    There are at least two different flavours of the power steering rack... So makes sure you can get the correct one if replacing. Externally I think they all look the same but certain sensors were moved between the rack and the control ECU.
  5. Default
    Quote Originally Posted by Hagasan View Post
    I'm getting the car through Torque GT however upon bidding I was aware of that the PAS was unstable when turning.
    But I always do my own fixing so I'm not too keen on paying for labor I could do.
  6. Default
    I have tried to find contact details for Kaz but had no luck
    Quote Originally Posted by mk1_nutter View Post
    Post a note into a blog or select email option from his avatar ....
    Or convert it to manual, there are a couple on eBay including one from Dr. Mikey.
    Good luck if you end up pulling yours apart yourself, let's hope you don't end up with an unusable core. The population of EPS racks could do without losing one, we're all going to need them at some point.
    Daily driver: Jaguar iPace HSE
    2000 NSX Coupe, Circuit Blue, was W2NSX now V6NSX
    Renault Megane RS Trophy R
    Other interesting mode of transport: Bell JetRanger
  9. Default
    Quote Originally Posted by flyingsniffer View Post
    I have thought about this but was worried ill then have some sort of dash lights on.
    Aug 2011
    South Wales
    Its been done a few times. Just unplug the EPS unit and you shouldnt get any dash lights. If you do you can just remove the EPS bulb from the cluster
    Also its a cheapish option to get your car on the road whilst you consider options on getting your rack fixed (as I know the waiting time is months)
    Not another NSX project!
    Porsche 997 GT3
    Porsche 981 Boxster S
    BMW E46 M3
    1998 NA2 Midnight Purple Targa Manual - Gone - to Thailand
    1999 NA2 Kaiser Silver Manual Track Car - Gone - and found its true destiny on the race track
    1992 NA1 Sebring Silver Coupe Manual -
    Gone (although still in my showroom in storage)
