Results 1 to 6 of 6
Thread: nsx-r metres issues please advise
    Default nsx-r metres issues please advise
    Hello guys
    mine nsx 1992 issue is i installed 02 nsx-r full gauges kit but guess what nothing working. why? how to fix?
    Thank you
    Quote Originally Posted by SennaNSXR View Post
    Hello guys
    Thank you
    I would hazard a good guess that the electronics are totally incompatible.
    The 92 uses basic 12v technology and the 02 gauges will probably work on can-bus signals, if so I would think that would be a major exercise to convert.
    Any idea how this can be solved?
    Quote Originally Posted by Pride View Post
    My guess was wrong as I've just read this previous thread so I'm sure it should be possible for your dash to work:
    http://www.nsxcb.co.uk/showthread.php?11013-Nsx-can-bus
    Presuming you are using the combination of NSX-R gauge circuit board and dials on 92 car, then first you must modify the pinouts of the chassis loom.
    Kaz can you be more detailed? where to fix and what please?
