[Edit: found your question after posting my original reply below....]
0.55 ohm at room temperature for your NSX.
0.32 ohm at room temperature for 97+ models.
Hi, Jonathan.
Can you re-create the same issue at idle rpm or raising the rpm while in P position?
It depends on the failure mode but if the fuel pump resistor block intermittently fails, you will have problem starting the engine or even keeping the idle rpm.
Therefore, it could be not related to the resistor block.
For your reference, the most common failure modes are;
- the internal crack of the resistor (you can't see it from outside). You may be able to re-create the same issue by spraying the ice cold spray.
- the intermittent damage to the crimped section of the wire just at the edge of the resistor terminals.
Example here;
http://www.nsxcb.co.uk/entry.php?205...mp-Resistor-01
http://www.nsxcb.co.uk/entry.php?205...mp-Resistor-02
If you can easily re-create the same issue, may be you can borrow the good resistor block from another owner?
I have two new resistor blocks at my place.
If it is in stock in Japan, I can release one of them for you but Honda Japan is closed for the new year holiday until 4th and then they will need some time going through all the email so won't get reply for several days.
I have one used resistor block with damaged wires.
If I can find suitable terminals, I can create temporary resistor block for you.
You are more than welcome to try it first before buying the new one, although it's not mega expensive so might as well replace it with new one if you are still using the original one.
If you can drive up to Bucks and if you are using the OEM fuel filter fitting, then you can use my fuel pressure gauge as well although with your issue, may not fancy driving the long distance .
Probably you will need measuring the fuel pressure while the issue is still there any way.
You can't rule out the fuel pump yet....
If you can re-create the same issue at idle rpm (closed loop once warmed up) but not getting the CEL, the fuel pressure is not low enough for the closed loop fuel control to max out on the trimmer.
There is no PF compensation in the closed loop calculation on our NSX.
Pressure regulator can fail but you will see on the pressure gauge.
Hope you can measure the fuel pressure while the issue is still there.....
