Results 1 to 10 of 10
Thread: Fitting HID
    Default Fitting HID
    So the sun's out, household bodies elsewhere - excellent, let's fit new lights
    ...except fall at the first hurdle - can't get cover screws out!! Soaked in penetrant etc, 3 stuck fast & just beginning to chew up
    Very frustrating. The technical aspects of fitting look v. uncomplicated - but I can't get in!
    Dan / whoever else has done it - was this a problem? Don't really want to attack with impact drive but would this be an option without breaking anything? My car is relatively high-mileage and lives outdoors so I suspect ally screws have corroded a bit. Any thoughts much appreciated...
    Still, the side repeater change was easy & makes a surprising difference to look of car. 8)
    Graham
    '93 Sebring Silver : sadly now sold
    '93 Range Rover LSE : now LPG so 11mpg not so bad. If I replace any more parts it'll be a new car.
    '07 Landie Defender 110 SW XS: heated seats!!! they'll be asking us to wash it next....
    '96 MX5 : project car
    '09 Honda XL125V : new hobby
  2. Default
    Hi Graham,
    This has been a problem for me on two occasions. What helped every time was to soak the offending screws in WD40 or penetrating oil and very carefully try and twist back and forth. When the screw does begin to turn resist the temptation to completely undo it - you may end up stripping the thread this way. Once again, apply WD40 and continue with the twisting backwards/forwards action. Eventually the screw will come out completely. The screws are actually made of nylon which is why it is so easy to strip the thread.
    I'm sorry I can't be more help - persistence in the only way forward!
    Good luck!
    Dan
    Finally done it - my headlamp cover screws are metal, and 1 simply wouldn't budge.
    After about 5 hours total sweating at it (not exaggerating..) eventually filed flats on the sides and got it with adjustable wrench - after attempting to drill it out...think the heat generated might have budged the threads.
    Anyway - the kit's an absolute doddle to fit. Thanks so much for expert fitting instructions Dan!
    (Only bit of consternation - my car has red - not white - power lead to bulb, so felt a bit counter-intuitive fitting red to black and black to red in conversion!)
    Had to go for a twilight blast to celebrate. Awesome difference.
    Just got to get the alignment checked at my local garage - they love the car! Does anyone else find they get a crowd around their NSXs anytime they park?? There's certainly a lot of the "I've loved those since they came out" type comments, don't really get the jealous-type ones...
  4. Default
    Hi Graham,
    Glad to hear you've managed to fit the kit! My apologies for the "incorrect" colour of the power wire ... It's one of those Japanese (logic) things. I've fitted these HID kits to quite a few NSX's now and have come across two distinctly different power wire colours: red (95%) and white (5%). I will make a note in the fitting instructions that these are interchangeable. Thanks for letting me know.
    Get that alignment checked and all the best with the kit.
    Best regards,
    Dan
    Glad to hear is that simple, got mine a few days ago and will have a go when time permits.
    Thanks for the help and patience Dan.
    AR
    ...are they pure white HID's or do they have a strong blue tinge?
    Dan offered all colors to the group buy. I went for 8000k with a blue color to them.
    AR
    Jul 2005
    Puerto De La Duquesa, Spain
    Mine fitted aswell.
    Thanks very much Dan, really easy to follow instructions.
    Dave
    Dave
    I'm not attracted by a womans mind, only what she doesn't mind!!!
    95 NSX Owner since 8 Aug 05 (sold Apr 13)
    Lamborghini Aventador Roadster
    Bentley Continental GTC
    Kawasaki ZX9R
  9. Default
    Quote Originally Posted by NSXGB
    Indeed I offered the 6000K and 8000K kits. The former is pure white with a slight blue tinge, the latter has a much stronger blue tinge.
    I can supply these kits in any bulb fitment so if you are considering upgrading another car then let me know ...
    Kits are purchased to order and are usually available within 7 working days. All kits come with everything you need to fit, including full fitting instructions and, in the case of the NSX, a short conversion wire.
    Club price is £250 delivered (rrp = £285 + p/p).
    All the best,
    Dan
    I had the same problems with rusted screws but otherwise the kit was very easy to fit. Recommended.
