Results 1 to 3 of 3
Thread: Na1 5 speed transmission for sale
    Default Na1 5 speed transmission for sale
    This is based in Northern Ireland, U.K.
    I had this gearbox as a spare but have decided I'm not going to need it.
    It is from a 1994 European spec car.
    The box was stripped and inspected- input shaft bearing and counter shaft bearing have been replaced, all else is perfect.
    £2500 or best offer
    Same gearbox and photos from the old thread here;
    http://www.nsxcb.co.uk/showthread.ph...d-and-mspected
    As in my comment, it may came off from the 94 European model, J4A4-100 series gbox was only used on the 91 model, longer ratio.
    As drmikey mentioned, it's also in the snap ring failure range.
    You may also want clarifying the above on your Ad on NSX Prime as well.
    Cn you delete this advert I have modified the other one, hadn't actually realised I had posted twice!
