Results 1 to 10 of 22
Thread: ozon02 - NSX story
  1. Default ozon02 - NSX story
    Disappointing story
    This year I have done some modifications - like this: Os giken Clutch, Os giken LSD with 4.40 final ratio and Tein shock absorbers.
    I bought a track day in the Czech Republic - Motodrom and in Slovakia - Slovakia Ring
    I booked the hotel I persuaded my wife and sent the kids on holiday. I ordered a tow truck and got on the road ...
    My NSX refused to cooperate - entering the tow truck came fail EPS, # 22 reset with the clock fuse. I started the engine EPS lamp went out and thought it was OK. But by turning the steering wheel, the EPS light shone again with the same fail # 22.
    I only had 2 hours to repair - later my trip made no sense.
    Has my NSX offended me for modificatioons ?
    Kaaz described the fault for my driver model (..... 023) burned relay contacts.
    I ordered this in the USA with enlarged contacts (delivered time approx. 2 weeks).
    On the web I suspect that the pins are in line with the standards. I decided to put another - from the Renault 70 Amper- (it does not like you Kaaz?
    Unfortunately, a diode was inserted in the trigger circuit. I missed the direction of the diode and damaged the transistor - it took me 6 hours to find this fault.
  2. Default
    It was difficult to solder the relay - I made a special tip
Name:	20170704_115543(1) (1024x614).jpg
Name:	20170704_115609 (1024x614).jpg
    23/5000
    But he was not warm enough
    One more time
Name:	20170704_115735 (1024x614).jpg
    I dismantled the relay housing - one of the lower corners was burnt contacts the second as newClick image for larger version.
Name:	20170704_115940 (1024x614).jpg
ID:	13060 Click image for larger version.
Name:	20170704_115954 (1024x614).jpg
    I measured the resistance of the coils (OEM and aftermarket) and compared with the catalog.Click image for larger version.
Name:	20170704_121822 (614x1024).jpg
Name:	20170704_121716 (1024x614).jpg
ID:	13062 Click image for larger version.
Name:	20170704_121731 (1024x614).jpg
    The aftermarket Relay was larger by 30mA. The coil transistor was on 1 Amper Current ( Catalog)
    But the difference in contact area was satisfactory
Name:	20170704_120055 (1024x614).jpg
    It's late (I'm going to sleep) but one question bother me - why the other of the relays (the good ones) during the switch vibrate the contacts (3-4 stroke)
    Regards
    Mario
    P.S.A little anger passes me
    Next occurence (frustrating) with the Air Condition Panel - reading the blog Kaaz noticed that he often repairs the AC Panel. Two years ago I bought from the USA (Prime)as a reserve.
    And my checked - no leakage capacitors. I thought it did not concern me. This year I bought from Chritian ATR only Front panel witch Celsius (We were Acura in Farenheit). When the ACC panel was opened - I nearly fainted - four capacitors poured out. It's a lesson for me that I ignored the Kaaz hints (absolutely replace all the capacitors). Now please Kaaz as far as possible which electronic components I should still check.
    In one year coincided - only faults !!!(clutch,EPS,ACC Panel)My Acura is 1996.
    P.S.
    During the rapid acceleration I noticed misfire in exhaust(This is the cause of the change final ratio to 4,40) ?
    There's no tool needed.
    Christ, I bet that was like watching paint dry ozon02 😂
  9. Default
    Yes you are right.
    I also gave the valve covers to this factory - but unfortunately I did not get the original effect.
    (I spent a lot of hours working on cleaning).
    I bought American paint (wrinkle plus) and try it myself. By heating a hot gun, you can influence the process of creating wrinkles so that you get closer to the original.
    Unfortunately, varnishing is my Achilles heel.
    The valve covers still look good. I've done the same and had about the same effect. Still better than before and nobody actually knows.
