Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: ozon02 - NSX story
  1. Default ozon02 - NSX story
    Disappointing story
    This year I have done some modifications - like this: Os giken Clutch, Os giken LSD with 4.40 final ratio and Tein shock absorbers.
    I bought a track day in the Czech Republic - Motodrom and in Slovakia - Slovakia Ring
    I booked the hotel I persuaded my wife and sent the kids on holiday. I ordered a tow truck and got on the road ...
    My NSX refused to cooperate - entering the tow truck came fail EPS, # 22 reset with the clock fuse. I started the engine EPS lamp went out and thought it was OK. But by turning the steering wheel, the EPS light shone again with the same fail # 22.
    I only had 2 hours to repair - later my trip made no sense.
    Has my NSX offended me for modificatioons ?
    Kaaz described the fault for my driver model (..... 023) burned relay contacts.
    I ordered this in the USA with enlarged contacts (delivered time approx. 2 weeks).
    On the web I suspect that the pins are in line with the standards. I decided to put another - from the Renault 70 Amper- (it does not like you Kaaz?
    Unfortunately, a diode was inserted in the trigger circuit. I missed the direction of the diode and damaged the transistor - it took me 6 hours to find this fault.
  2. Default
    It was difficult to solder the relay - I made a special tip
Name:	20170704_115543(1) (1024x614).jpg
Name:	20170704_115609 (1024x614).jpg
    23/5000
    But he was not warm enough
    One more time
Name:	20170704_115735 (1024x614).jpg
    I dismantled the relay housing - one of the lower corners was burnt contacts the second as newClick image for larger version.
Name:	20170704_115940 (1024x614).jpg
ID:	13060 Click image for larger version.
Name:	20170704_115954 (1024x614).jpg
    I measured the resistance of the coils (OEM and aftermarket) and compared with the catalog.Click image for larger version.
Name:	20170704_121822 (614x1024).jpg
Name:	20170704_121716 (1024x614).jpg
ID:	13062 Click image for larger version.
Name:	20170704_121731 (1024x614).jpg
    The aftermarket Relay was larger by 30mA. The coil transistor was on 1 Amper Current ( Catalog)
    But the difference in contact area was satisfactory
Name:	20170704_120055 (1024x614).jpg
    It's late (I'm going to sleep) but one question bother me - why the other of the relays (the good ones) during the switch vibrate the contacts (3-4 stroke)
    Regards
    Mario
    P.S.A little anger passes me
    Next occurence (frustrating) with the Air Condition Panel - reading the blog Kaaz noticed that he often repairs the AC Panel. Two years ago I bought from the USA (Prime)as a reserve.
    And my checked - no leakage capacitors. I thought it did not concern me. This year I bought from Chritian ATR only Front panel witch Celsius (We were Acura in Farenheit). When the ACC panel was opened - I nearly fainted - four capacitors poured out. It's a lesson for me that I ignored the Kaaz hints (absolutely replace all the capacitors). Now please Kaaz as far as possible which electronic components I should still check.
    In one year coincided - only faults !!!(clutch,EPS,ACC Panel)My Acura is 1996.
    P.S.
    During the rapid acceleration I noticed misfire in exhaust(This is the cause of the change final ratio to 4,40) ?
    All cars need some attention after 20 years. As they equipped the NSX with quite a lot of electronics more things need to be addressed after these years. I don't dare to imagine todays rolling computers after even 10 years. When they will be exported to Africa all the electronics will be ripped out of the car. Ok, a little bit OT.
    Well, 20 years for a CCU is not bad at all, they normally begin to fail after 12-15 years or so (with the quality of caps they used originally). You need to replace ALL caps. And that's better done BEFORE the unit shows suspicious signs.
  8. Default
    I have more and more free time ....
    I decided to do some outstanding work ...
    1.Alternator color change
    I dismantled the alternator and painted the aluminum casing at the factory with stove varnish paint
    New Bearing
ID:	13877Click image for larger version.
    Christ, I bet that was like watching paint dry ozon02 😂
  10. Default
    Yes you are right.
    I also gave the valve covers to this factory - but unfortunately I did not get the original effect.
    (I spent a lot of hours working on cleaning).
    I bought American paint (wrinkle plus) and try it myself. By heating a hot gun, you can influence the process of creating wrinkles so that you get closer to the original.
    Unfortunately, varnishing is my Achilles heel.
