Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 136
    Looks good mate ��, what make and model are they???
    BC Racing, BR Series, 10Kg springs front and rear. I'm very impressed with the quality of them after fitting them to 1990 Prelude last year and a mate has them on his S2K and he raves about them.
    I should have recognised them.
    Good choice.👍
    I had those exact make and model installed to my NA1 about 18 months ago, I initially had an occasional slight knocking noise from the left front but after a couple of months use the noise disappeared.
    Also had to have them on almost maximum ride height adjustment for acceptable clearance over undulating roads but very well worth doing I must say.
    I wish I'd cleaned my suspension and underbody as thourghly as yours though.👌😎
    Had a slight leak from drive shaft seal.
    New seal almost in.
    A mate made me a seal tool using his 3D printer and the end off a broom handle, worked a treat and I used the old seal to contact the new seal.
    Removed the inner boot to tap shaft back into the diff and found the grease was like suds, so re-packed it with fresh grease and filled gearbox up with MTF3.
    New bolts for oil cooler arrived from Japan this week, only took 10 days from when I ordered them, so RH rear upper arm could go back on.
    Rear BC coilers now fitted
    and anti-roll bar.
    Started to refill coolant, waiting for another 10 litres to arrive.
  5. #15
    Exhaust now modified with valves, just need to plumb the vacuum parts up.
    Test pipes made, in place of CATs.
  6. #16
    Discs back from being re-ground.
    Car back on ground after 6 months, just waiting for my new wheels to arrive, hopefully this week, then ride height can be adjusted, before the trip to Centre Gravity for alignment. MOT on Thursday, so should be road legal at the end of the week, FINALLY !!!
  7. #17
    Aug 2009
    Which wheels (& tyres) have you selected?
  8. #18
    Having some of these https://www.driftworks.com/work-wheels-emotion-t7r.html
    17in front 18in rear, mainly due to the fact that Work wheels offer bespoke offsets, where most other aftermarket brands, don't.
  9. #19
    They should look pretty good. What colour?
  10. #20
    Matte Gunmetal, black centres.
