There is a common problem with the door locking actuator mechanism. However the usual symptom of this, is a repeated clunking from the door, after locking or unlocking. This is becuase the system doesn't think the door is locked or unlocked and keeps trying. It doesn't make the door unlock. I have sometimes found that my door lock is very sensitive, meaning I can lock the door, then when turning the key back to take it out, the door unlocks, like I've turned a bit too far. It's not possible that the alarm is unlocking the door is it?
