Hello All,
Just a quickie, my car had a large service about 1000 miles ago at Norton Way. Driving home last week the red (top left) oil light came on. I pulled over immediately and called for help (Papalazarou to the rescue so to speak) and waited for the oil to drain down, about 30 mins+. When the light came on the pressure guage was showing about 7, where it sits most of the time.
Anyway when I checked the oil on the dipstick it is very clean (the oil that is) and was toching the upper most drilled hole which I assume means it is 'full' so to speak. I actually at this point only being a few miles from home summized that it has to be a fault with the switch / sender for the light - as full oil pressure and oil to the top marker on the dip stick in my simple mind means there are no low oil problems...or I hope so...and drove back.
I had a lot on this weekend so didn't drive the car or deal with the problem, but got back in this morning and checked the oil again, exactly the same, so started it up and drove to work. Light flickered a bit and then went off after a mile or so...and stayed off for 60 miles, and then made a re-appearence a few miles from work again. I would like to try and find out the problem before getting the RAC to take the car to my local Honda garage and save a few hundred quid if possible on diagnosis, does anyone know anything that might shed some light on this for me...? Any coments greatly appreciated!
Matt.
