Results 1 to 10 of 45
Thread: Jaffaz32's Boosted Stroker Build
  1. Default Jaffaz32's Boosted Stroker Build
    Sorry about the copy and paste from Prime,
    Thanks to everyone who has been in contact over the last couple of days wishing good luck with the build.
    Previously i owned a 300zx for about 6 years, this was my first attempt at building a fast car and took a naive approach of power power power. The car had the power but the setup was awful. The car was savage but didn't put it down and was unpredictable in terms of the delivery.
    I learnt along the way the right way of building a fast car.
    I started by raising the boost on the stock motor which was getting towards the end of it's life, decided to do a mild forged build that netted 520bhp (Flywheel) and lasted about a month. Basically Scholar Engines who apparently worked with Lotus and the Elise when it came out machined my block and heads and knife edged the crank, they slipped while knife edging and scuffed a main bearing journal, the machine shop assured me this was only cosmetic damage at the time being naive i took their word for it, but... i then couldn't everyone refused to build my engine with that crank, in the end the machine shop built my motor, after a month the motor seized, it blew most the oil out the exhausts. Guessing it was down to the crank! The garage pretty much screwed me over.
    Anyway after that i spec'd the motor for 900bhp, i ordered all the parts. I sent the car to Thor Racing in the UK who stripped the car to almost bare shell, they had it well over a year getting on for two over that time they hardly done anything except strip the entire car and the engine itself. Time came where i decided enough was enough, this is never going to get done. So we went up there, after being locked in a office and threatened by the garage staff not to speak of this i returned home with a shell and boxes upon boxes of random parts new and used. Realistically no garage was going to take on this job without big expense. This garage had been charging me over the duration they had the car and not making any real progress, they also stole some of my parts again i got stitched over. The car ended up being weighed in for scrap metal and the parts sold on.
    Before scrapping the 300 I started talks with a Rx7 specialist who built my brothers Rx7 about having a quad rotor (26B) built and dropped in, the idea was to sell all my parts and go down this route. Until i really considered what i could buy for the money and admitted that car was just a bad omen. At the time Ferrari 355's, TVR's, Aston's etc were reasonably priced which i considered but i knew it would be a bad idea with my urge for more power, it had to be Japanese. I wanted to go the next step from the 300zx, it came down to 2 options Nsx or R34 GTR.
    I bought my Nsx roughly 5 years ago a pretty much stock low mileage Charlotte Green C30A 5 speed Na1.
    The car was owned by the family of Walkers crisps in the UK for most it's life and has a comprehensive service history, trailer receipts for services etc. you name it.
    The car was spotless, I loved it but wanted something a little different in both power and looks.
    So i started doing basic mods, LSD's, body work etc. I went down the NA route initially ticking most options, but was very limited to what i could squeeze out the stock motor. Over the years it went from looking stock to subtly modified to the race car look. I had done allot of mods like STMPO Messiah exhaust system, Downforce intake etc.
    I closely followed the forums, anytime anyone had a scare for example the crank pulley failing, water tanks splitting, oil pump gears cracking i straight away ordered the aftermarket upgraded parts. The car was mechanical sound. I covered most basis except the brakes at the time
    This is when i started considering turbo kits, i really had my heart set on a single, as previously owning a twin i liked the sound single's produced and wanted to do something different. I looked at all the turbo kits on the market and went with Cody's and pick a few upgrades and custom options, GTX turbo, full ceramic coating of manifolds, turbo and exhaust system. Cody build me a custom exhaust, that had a Cat bolt in option and came straight out the back in the middle as a twin pipe.
    Before purchasing Cody asked me to do a compression test, which i did. All cylinders were pretty close to each other with the exception of cylinder 6 which was just within tolerance, so i knew at some point i would need to install new pistons which i decided to purchase at the time along with head gaskets for a mild build. I never got round to installing these due to expense and not being sure if that was to be the spec i wanted to run, so still sitting in their boxes.
    The install of the turbo kit was kinda a disaster but rewarding in the end, i saw that Angus kit was DIY and asked Cody could his kit be installed by a normal garage or needed to be a more specialized garage. I couldn't see why not so i arranged with a small one man garage who was a Honda enthusiast to install my turbo kit with my help, the day i got there to start the install he came hopping out the workshop and said chris i don't want to scare you but i've damaged my leg and will assist you with the install. I ended up doing most the install myself, i had done my homework knowing how most of it went together. So off i went, he didn't really help at all. I managed to get it all installed and running on a base map supplied from Cody on the FIC. The car ran fine. He then had the cheek and turned round charging me about half again the initial agreed quote for the install. He said i ran over to which i replied, no **** of course i did. I'm no mechanic, you didn't do the work as agreed with my help, i did it with very little help. that got a little messy. Again i got stitched over by another UK garage.
    Anyway, i got the car tuned. It seemed to drive great on the way home and for the next couple of days then after a short while the car kept throwing me out of boost well seemed the car would just kill power mid pull and come back. Replaced loads of parts, Coils, igniters you name it. Went back to Cody who helped me with simply diagnostics. Cody assured me that a guaranteed route to resolve the issue would be going with the AEM Infinity. I was hesitant because it was sold as a kit, how easy would it be to install? who would tune it? Cody said it was pretty easy to install but i still wasn't sure and didn't want to take it to a garage who would charge allot of money per hour, having to spend days on installing it. So i decided the best option was to fly Cody out to install the Ecu and tune it, which is what we did. Install was actually very easy, Cody had the car running on the first day, over the duration we got the car road tuned and then dyno tuned. It drove perfectly the issues had gone that i was experiencing with the FIC. While Cody was here he said "Chris, your oil pressure is a little low." if it wasn't for the Infinity I would of had no idea as the gauge on the dash looked fine, so the Infinity basically kinda saved me, well made me aware of a potential serious issue. When tuning the car we had to slightly lower the oil pressure safety parameters to other cars to stop the infinity going in to safety mode until i resolved the issue. At this time the oil pressure could had been just the oil i was running, maybe the external oil cooler because the lines were crazy long or maybe even a faulty sensor. Cody had set flights to return home, the car done over a 200 mile round trip dropping Cody off at the airport with zero issues, we sat in about an 2 hour traffic jam on a hot day, no issue.
    I then changed the oil, for a while it all seemed ok.
  2. Default
    Then over the next few weeks/months the car started playing up. Cody talked me through looking in the logs the power cut was the Infinity going in to limp mode due to the oil pressure once again. From there i changed the oil again but removing my billet purepower reusable filter to a normal type, eliminated and tested all oil related things i could externally, bypassing external oil coolers, new sensors. I tested the oil pressure per manual with a mechanical gauge. The issue appeared to be internal.
    Now the Dilemma i faced.
    Specialist garages charge crazy money. I didn't want to pay to have the engine removed and stripped just to be inspected as i would had to wait months for any parts or what if it was something major like a crank, full motor build etc. After speaking with Cody and going through different scenarios i decided to go on the basis of worst case. It sounds a little crazy but... it's so hard to get parts here and with the unknown of what was wrong or involved, i opted for a full build because i would have a car that is mechanically sound and trouble free with the peace of mind and confidence to drive. I thought to myself i've been here before!! my 300zx built motor blew up after a month. So i decided to over spec the motor for a element of safety. I can only afford to do this once so do it right. There was a possibility the bearing had gone due to the symptoms and going on worst case i decided the crank had to be replaced to be on the safe side. this meant stroker kits, i spec'd the engine for around 800-1000bhp i wanted to tick every box and dot every I.
    I contacted several garages and specialists and decided to take my car to Plans Performance.
    As we speak the car is currently in bits and with Plans, they were just as excited as myself when dropping the car off to be working on this project. The motor is apart and with the machine shop as of typing. They found that one of the bearings had gone. They have sent a comprehensive email with a to do list of other things they have found that needs addressing which is good as again I know in the back of my mind that the car will come home completely mechanically sound. So far so good with Plans but a little anxious based on my past experience with garages, time will tell.
    I will post a complete spec list later with more details and info but this is a start at least.
    So as you can see i have had my share of bad luck in terms of cars, i'm a decent guy and garages take advantages of this and stitch me up in the past. I'm a little nervous but very excited.
    - - - Updated - - -
    When i spec'd the motor i wanted to replace everything oem while building.
    I ordered the oem motor rebuild kits (these do not contain everything)
    I then went online and printed off the exploded diagrams for the motor, oil systems, wiring, throttle body etc. etc.
    I then cross referenced what parts i had and ordered every single gasket, seal, grommet and including all brand new sensors for everything... Some sensors were expensive like the knock and crank angle but as mentioned above i could only do this the once and needed it to be trouble free motoring.
    I wanted to spend a little extra now to ensure i had a brand new motor for complete reliability and trouble free motoring.
    Quote Originally Posted by jaffaz32 View Post
    - - - Updated - - -
    Great story behind the build jaffaz32, you're obviously not holding back on the horses with this project are you???
    What WHP are you hoping to achieve and what sort of time scale before you hope to get the finished monster on the road again???
    Looking forward to updates on this if that's ok???
    The motor has been spec'd for 800-1000 Whp but i don't want to push my luck and run safely within a safety margin.
    Next limiting factors are the gearbox, turbo and injectors.
    gearbox is recommended to support about 550whp, that being said with my engine management i have restricted boost in first and second gear also 12 boost settings so if i was to push the gearbox is would only be a fraction of the time when in the highest boost setting and not where the damage would be done most off the line with the restriction in 1st and 2nd.
    The turbo and injectors will need upgrading for anything above 600-650
    I think playing it safe would be around 550 ish. It's hard to say though as with the increased capacity i would require less turbo pressure to hit the desired bhp. I will make the tuners aware of the gearbox and see what they come back with.
    Timings i was hoping to get it on the road in time for my brothers wedding (8th July) however i rather it was built right and not rushed, if it ran over it wouldn't be the end of the road.
    I plan to keep everyone updated
    I got an email first thing this morning saying my brake rotors are on their way back from being Cryogenic Treated.
    The process involves freezing them to -195 degrees.
    The process removes imperfections in the metal and can increase rotor and pad life up to 300x (apparently)
    It also helps with brake fade which I have experienced in the past. My brother found it highly amusing that i had limited brakes three quarters way around the ring and it was still braking hard.
    Current Spec:
    Body Work:
    Carbon Type R bonnet (color coded)
    Custom Front bumper
    Led front side lights
    Carbon front splitter
    Carbon Canards
    Downforce Carbon Intake vents
    BYS clear indicators
    APR GTC Carbon wing
    JDM rear upper bumper
    Seibon Carbon lower rear bumper partly colour coded.
    Custom rear diffuser
    LED tail lights
    Brakes, Wheels/Tires:
    Advans 17/18 in Satin black
    Dunlop Z2's
    EBC rotors and yellow stuff pads all round (on the upgrade list)
    Drivetrain:
    1.5 way LSD with ring and pinion
    DriveShaft shop rear axles
    SOS Carbon clutch
    Suspension:
    BC coilovers with Swift springs
    Non compliance rear beam
    Urethane steer rack bush
    Non compliance front clamp set
    Adjustable drop links front/back
    Adjustable rear toe links
    Carbon6 front ball joints top and bottom
    Dali front/rear strut bars
    Interior:
    Bride Gias Carbon seats
    Takata harnesses
    Route Ks harness bar
    Carbon centre console
    Nsx navigation panel
    triple gauge pod
    Electronics:
    LoveFab AEM Infinity 10 Engine management
    AEM AQ1 datalogger with GPS
    Various gauges
    Gauge Art on Honda Nav screen
    Cooling:
    Koyo Rad
    New oem coolant hoses
    Aftermarket coolant tank
    Turbo kit:
    LoveFab with GTX upgrade, custom exhaust and ceramic coating.
    New Motor currently being built by plans:
    Block:
    Brian Crower 3.4L Stroker kit. - Brian Crower crank, Brian Crower Rods
    JE pistons
    Darton Sleeves
    ARP head bolts
    ARP block bolts
    Cometic gaskets
    Science of speed oem oil pump with billet gear
    New water pump
    full set of oem sensors
    full set of oem gaskets/seals
    baffled sump
    Power Enterprise timing belt
    Aftermarket stiffer engine mounts
    ID 725cc injectors (to be upgraded next year)
    Ati Crank pulley
    SOS EGR kit
    SOS oil sensor upgrade kit
    Heads:
    Full polish n port
    Brian Crower springs
    Brian Crower retainers/seats
    Supertech valve guides
    Supertech stem seals
    Ferrea oversized intake valves
    Ferrea oversized exhaust valves
    Comptech cam gears
    SOS LMA kit
    Full seat of new gaskets/seals
    We are slightly changing the plumping of the oil feeds within the turbo system and upgrading to Russell braided lines and fittings.
    Also tapping the pan for a temp sensor
    Left it open with Plans regarding an oil cooler, i had supplied the parts from the SOS kit i removed.
    Cleaning up the engine bay by removing anything no longer in use as suggested by Plans, less to put back on
    First off Plans wanted to see the car running before starting work which is fully understandable, I was waiting for the AEM to return from USA after being upgraded, sent it straight to Plans and they started working on the car.
    End of first week I received a detailed email with some advisories which was listed in order of priorities, this was outside of the engine build that covered a worn ball joints, corroded rose joints etc. Was good to see as this was using initiative to give the car a quick go over and flag anything else that may need attention.
    Sorry i still haven't uploaded any pics, i can't seem to post them from Instagram in to the thread so will have to upload all to onedrive.
    A little update.
    We had a few hold ups, first was the engine shop as they were busy before fitting me in, then we have been waiting for parts on 3 occasions and we all know what that is like.
    The block and heads are back from the machine shop, i believe the heads are now built. The block is being built but waiting for bearings to arrive.
