Are these a requirement for MOT or could they be removed to install brake cooling ducts like Darren did on his track machine.
AR
AR
No requirement for front foglights only for rear.
Chris.
AR,
If you do remove I think you'll find a home for them if you dont intend to keep ...... might help to fund your upgrade.
regards
I've had no probs with the MOT either, but I tape over the switch with insulation tape.
My theory is that if they can't see the switch, they can't try it, and then want whatever should be connected to it work.
Cheers lads all taken onboard.
AR
.... and they are hopeless as fog lights anyway....
