-------------------------- Update ----------------------------
Back up for sale in new - OEM+ spec with high resolution photos and a new price of £23,995:
http://www.pistonheads.com/classifie...6-1991/2265037
-------------------------------- anything below is now old and does not reflect the current condition of the car.
Hi all,
I have decided that now is the time to move on from my NSX and go for the 360 that I have been dreaming of.. I will post the car up here for a week or two before it goes on Pistonheads to give my fellow club members a chance to get in first
NSX NA1 Coupe 1991
JDM imported in 1998
5 Speed Manual (JDM short gears)
61k
12 Months MOT
4 Month Tax
Full Honda Service History since import, Manchester Honda looked after the car until 2011, since then Norton Way Honda have looked after the car.
Standard features on the car are Electric Windows, Air-Conditioning, Electric Seats, Electric Mirrors, Cruise Control, Traction control, Stereo, Half-height Electric Aerial.
Thousands have been spent on OEM parts to help restore the car to a high standard, replaced parts include:
- Replaced windscreen
- Water Pump replaced
- Water Pump cover replaced
- Harmonic Balancer replaced
- Crank Pulley replaced
- Timing Belt replaced
- Compression check
- Replaced driver side electric window switch
- Replaced gear shift boot with face-lift NA2 NSX-R shift boot
- Replaced complete headlining
- Replaced clutch slave cylinder
- Replaced rear brake calipers
- Replaced rear brake lines
- Replaced handbrake cables
- Replaced gearbox fluid
- Replaced rear brake splash guards
- Replaced rear brake discs
- Replaced rear brake pads
- Replaced rear brake hardware
- Replaced front OEM brake setup with StopTech calipers, discs, pads, braided lines
- Hub threads repaired
- 4 x Wheel bearings replaced
- Fit lowered suspension springs and new rear shock absorbers
- Replaced Rear windscreen struts
- Replaced aircon resister
- Headlamp wiring repair
- Lubricate window channels
- Replaced Oil pan gasket
- Replaced Water hose
- Headlamp motor replaced
- Recent service including oil and plugs
- New battery
The car benefits from the following sympathetic modifications:
- Personalised 'NSX' numberplate
- Skunk2 shifter
- Clear side repeaters
- Rota Grid staggered wheels with Falken tyres (18" 8.5j front, 19" 9,5j rear)
- Carbon Fiber center console
- Carbon Fiber interior trims
- Tein Springs
- Test pipes
- Face-lift NA2 exhaust manifolds
I will be aiming for a £23,950 ONO price. You can contact me by PM or email: tokyo.silvia@gmail.com.
No time wasters or tyre kickers please, test drives on a car like this are not likely but I am happy to take serious parties out for a drive.
