Results 1 to 3 of 3
Thread: Valve Adjusting Tools
    Default Valve Adjusting Tools
    To adjust the valve clearances; Honda show what is effectively a deep 10mm tubular socket or box spanner with a hollow nut/flats on its other end [tappet lock nut wrench 07MAA-PR70120] that will accept a screwdriver shaft [tappet adjuster 07MAA-PR0110], both of which look manufacturable. Can anyone advise the overall length and external diameter of the box spanner and the overall length and head diameter of the screwdriver.
    Many thanks, Duncan
    Default Valve tool
    Hello, here are the dimensions of the Valve tool.
    The Nut section is 17 mm top
    Lenght is 115 mm
    Inside is a 10mm to go over the Valve nut (bottom)
    Hope this helps
    Bram
    Many thanks, Duncan
