Silver '93 NA1 is in long term storage and has been on a battery conditioner for a few months. Called the company today to say that I would collect it and they called back to say it won't start: engine will turn over just fine but it will not fire into life.
First question was about the immobiliser on it (Toad I think), but that seems to be working OK as the starter turns. (Unless there's likely to be a second immobiliser circuit that interrupts fuel/spark/etc?)
So, I just did a search here and found Kaz's excellent postings - about the main relay controlling fuel/etc and the starter being on a different circuit. And I've seen a few mentions of the relay's solder joint issues and where to find it on my non-DBW car.
The car is however, several miles away, so I'm wondering if there's any other diagnostic check that can be done with the relay in situ?
Or do I just buy a new relay, swap it in and see if it works?
Or do I swap in the main relay from my other NSX ('95) to check? Logic says that this would be an obvious idea, but I know that if there are any marginal solder joints on this one, disturbing the relay may break them and I could have 2 non-starting NSXs!
