Originally Posted by
Hi Luke,
New RB discs, fresh pads and a caliper overhaul would improve what you are currently experiencing and 'feel' better straight away. I would suggest about £2k to do this work.
If you're going for looks, then the Stoptech I believe is built to the same balance (or very close) as the OEM set up and have the added benefit of fitting within the OEM 17" wheels. you will be into around $5k plus shipping and taxes for the complete plug and play set up.
This.
And what Kaz say.
Once you start b uggering round with different tyre sizes and different brake specs. the original algorithms (there is a lot of diff. calculus & stuff involved) all go out the window. Even my AD08s probably have a coefficient of friction they would have presumed only for the very best track tyres back them.
You might gain better initial bite, but find you have premature lock-up in extremis.
All I know is, I don't know enough about it an thus I only make microscopic modifications to what Honda's engineers and their Kray did.
Put it this way; if they felt the NSX-R set up was as good as it gets for this old car, that's probably what to go for.
IME, Honda brake pedals go a bit 'blergh' later in life. I think this is due to non-flat disk surfaces, softening hoses or soggy M/C seals. I've tried pads & calipers, but it seems to make things worse if anything (Civic & Lude).
I'd go for an official 'refresh' . Mine has Project Mu disks, pads and I believe, braided hoses and it's the best stopper with the hardest pedal. The S2000 has lost its (fantastic) edge in feel, due to hard use of disks, which look like records.
Nick
