4 Attachment(s)
As seen on many NSX and also in the previous post, IGN Coils at the rear bank were corroded/rusted due to moisture passing through the IGN coil cover gasket.
Attachment 8083
As you can see, there was clear marking on the rear bank valve cover that the moisture stayed there for long period.
This will happen on any NSX if the rear bank IGN coil cover gasket was not replaced or if it was not massaged with silicone grease at a certain interval.
Even just washing the car will cause the same problem if the gasket was already tired.
Attachment 8084 Attachment 8085 Attachment 8086
Without taking the engine out, you need to be very careful on re-assembly or installation of most of the parts during TB service.
On this NSX, the Front Valve Cover gasket was dislocated during the re-assembly and being cut resulting in oil leakage around the engine block as well as allowing some of the oil into the inside of TB Mid and Lower cover.
Addition to this, in UK, quite often the WP is not replaced during TB service and the lower cover was being re-used. On this NSX, the expensive rubber seal was missing from the TB Lower cover. Glad that we decided to carry out the TB service this time before it’s too late.
4 Attachment(s)
Spent extra time cleaning the engine.
Attachment 8095 Attachment 8096
Attachment 8097 Attachment 8098
Some of the before and after photos. Cleaned as much as possible.
After removing the mid covers and before going any further, I normally install the new seals/gaskets with small amount of liquid gasket to cure it in time for the re-assembly.
5 Attachment(s)
Attachment 8101 Attachment 8100
Attachment 8103 Attachment 8102 Attachment 8099
So, new seals on the Front/Rear mid TB, Lower TB, Valve and IGN coil covers were installed.
Don’t ask me where these were done…. I promise that I kept the carpet clean.
Backed off the valve clearance adjuster in preparation for removing the four camshafts.
In the process of replacing the WP.
More to follow.
5 Attachment(s)
Attachment 8106
The oil seal at the Crank shaft/Oil pump was very clean and no sign of leakage so it is going to be re-used.
As mentioned previously, the WP was never replaced during the TB service on this NSX. It was still using the old original design.
The position of coolant seepage hole was changed on the later design.
Attachment 8108 Attachment 8109
The old design on the left and the new one on the right. The TB Lower cover is also different because of this seepage hole position.
Attachment 8110 Attachment 8111
As the entire seal rubber was missing from the Lower cover, the WP driven pulley was somewhat rusty and some dirt managed to get inside the TB area.
5 Attachment(s)
Attachment 8112
Over the years, it is quite normal to see small amount of coolant seepage.
WP, Lower cover and seal rubber are going to be replaced with new ones during this service.
Attachment 8113 Attachment 8114 Attachment 8115
Scrape off any corrosion from the mating surface of WP.
In the process of removing the old red sealant which is pre-applied to all of the WP bolts.
New OEM WP bolts with red sealant.
Attachment 8116
New WP installed and torqued to the spec.
4 Attachment(s)
Attachment 8117
Temporarily, re-installed the Oil cooler base with remaining two cooling system hoses to carry out the leak check.
While testing the cooling system, started removing the camshafts holders, covers and camshafts.
Attachment 8118 Attachment 8119 Attachment 8120
O-ring at the dowel pin under the #1 cam holder has to be replaced with a new one.
Looks like during the previous TB service, the original liquid gasket (white one) was not cleaned before applying the new one (black one). Another reason why I saw many engine oil seepage from the valve cover and camshaft black cap area.
As seen on all of the NSX, the black compound of CKP/CYL sensor was melting and running down the back plate.
3 Attachment(s)
Attachment 8123
Left the leak tester for more than 20min and not a single movement of the needle so I'm happy with the cooling system.
Attachment 8124 Attachment 8125
Both Camshafts from Front bank are removed and being cleaned. Engine block ready for another cleaning session.
Rear bank to follow.
I better start cleaning the house as my boss is coming back and I still have lots of parts inside the house.
More to follow.
5 Attachment(s)
Been busy with other projects so couldn’t spend much time on this NSX recently but now I’m back.
Attachment 8128
As seen on many NSX, the cable for one of the Oil pressure sensor was trapped in the past. It could easily trigger the low oil pressure warning light but the owner didn’t mention anything so probably the internal wire was fine.
If you take your NSX to the normal garage or main dealer, during standard TB/WP/Valve adjust service, your camshaft won’t be removed.
However, there are tiny-tiny oil jets and passages on the cam holders and over the years, it will accumulate the sticky debris from the blowby and so on.
Attachment 8129 Attachment 8130
The dirty oil passage on one of the cam holder and this can be seen on almost all of the engines. You are relying on these oil passage and jets for the lubrication of camshaft and so on. Another reason to remove the camshafts and thoroughly clean the passage at the time of TB service.
Attachment 8131 Attachment 8132
Front Bank and Rear bank camshafts cleaned and inspected for abnormal wear.
5 Attachment(s)
It seems that the black liquid gasket that was used during the last TB service was applied without the surface being degreased. It came off by just wiping off with my fingers.
Attachment 8138 Attachment 8139
Attachment 8140 Attachment 8141 Attachment 8142
Before and after cleaning the old liquid gaskets.
5 Attachment(s)
Attachment 8143 Attachment 8144
Applying Eng oil before installing the camshaft. Also, applying the oil to the rocker arms.
Attachment 8146 Attachment 8145
Double checking the toque of camshaft pulley bolt.
Carefully tightening the cam holder bolts in sequence using the small digital torque wrench.
Attachment 8147
Front bank done.
On some of NSX engines, the 5mm parallel pin punch won’t fit into the hole at the Front exhaust camshaft and the holder cover [Edit: when] it was set at #1 TDC. This engine was the same so had to move the cam just a tiny amount to insert the pin. We don’t use this hole/pin for the timing alignment and just using it to lock the cam to prevent any movement so not a problem.
Moving onto rear bank.
More to follow.
