quick and easy boring oil change 144948miles!
just completed my christmas eve/christmas day/boxing day epic ABS upgrade....
from this
http://i1376.photobucket.com/albums/...psjkjji9q3.jpg
to this
http://i1376.photobucket.com/albums/...ps75nvl2ax.jpg
read all about it here.....
http://www.nsxcb.co.uk/showthread.php?14339-ABS-upgrade
Looking good! You did stop for Christmas dinner though?! :D
quick one today... cleaned the car, and thought i'd make sure the drains in the front boot corners were clear, so a gentle prod and squirt with the hose saw them sorted, but then noticed the rear corner on the drivers side had a puddle.....
https://farm5.staticflickr.com/4323/...a4c5ecb4_c.jpgWP_20170310_16_50_45_Pro_zpsduxl7gz3 by jon sutherland, on Flickr
https://farm5.staticflickr.com/4300/...06b7b9dc_c.jpgWP_20170310_16_51_03_Pro_zpsqyvwp93p by jon sutherland, on Flickr
def a puddle!!!
so undo the lamp nuts on the drivers side, and gently pull the outer end away from the car, not too far, as the centre piece stops it coming off, I just need to get to the drain channel between the 2 light seal gaskets....
here's the problem...
https://farm5.staticflickr.com/4307/...12a2bc3e_c.jpgWP_20170310_16_55_12_Pro_zpstdepenxi by jon sutherland, on Flickr
the 'square' in the middle of the pic is the drain channel coming up from the bottom...this is supposed to continue up behind the black plastic bit.... but is blocked by crud! better tease that out then, and give it all a rinse to clear it and reassemble!
once back together, another check....
https://farm5.staticflickr.com/4322/...77cbc486_c.jpgWP_20170310_17_06_27_Pro_zpswdugqa0x by jon sutherland, on Flickr
that's that sorted then!
fortunately i'd replaced the gasket seals previously so they still had a nice spring to them, so not worried about them not sealing.... i do have another set for when i do the respray, but one thing at a time!!!
....and i did notice i missed the edge of the light when i cleaned it!
quick oil change, as i bought enough oil to do the NSX when we changed the cube engine..... 147K miles... looks like it was a bit early, but hey-ho, it's just a quick oil change!!!!
Just curious Jon, did you tighten the sump plug up to 33lb/ft of torque with a new crushable washer or just nip it up to what you thought was tight enough???
Workshop manual quote:
"No special tool is needed for an oil-change; however, make sure you use a new crush washer in and apply the right torque. The manual specifies 33lb-ft of torque on the oil pan drain plug and
16lb-ft (one turn) on the oil filter (after applying oil to the rubber seal and using a NEW crush washer - reusing the crush washer will mess up this torque reading)."
The reason I ask is because over the 20 years of changing the oil and filter each year and torquing up as suggested above and regularly changing the sump plug for a new one.
But two or three years ago the threads became very weak when approaching that torque setting to the point of needing to insert a helicoil kit and wondered if anyone else has experienced this problem. So now I just nip it up tight enough because the helicoil cannot be taken to 33lb/ft torque.
And as for torquing up the oil filter, just hand tight for me.
Here's an interesting link on the subject:
https://www.nsxprime.com/FAQ/Mainten...luidfilter.htm
a quick bit of paint restoration....
from this
https://farm5.staticflickr.com/4321/...4b721197_c.jpgWP_20170617_12_46_42_Pro_zpsgduzltah by jon sutherland, on Flickr
to this...
https://farm5.staticflickr.com/4302/...a82c8679_c.jpgWP_20170617_13_34_02_Pro_zpsvdq0d1n6 by jon sutherland, on Flickr
http://www.nsxcb.co.uk/showthread.ph...099#post124099
you know when you get a niggle detail that bugs you, you know, the bit no-one else notices.. well, finally sorted one this week... the sealing rubber between bonnet and bumper was manky, kept going green as it lives outside....
https://farm5.staticflickr.com/4320/...a3590c7f_c.jpgWP_20170619_21_24_05_Pro_zpssajtplsh by jon sutherland, on Flickr
so purchased a replacement seal....
https://farm5.staticflickr.com/4323/...ff75a0e9_c.jpgWP_20170624_10_07_05_Pro_zpsrjdddvyx by jon sutherland, on Flickr
better.....
https://farm5.staticflickr.com/4308/...e0e9c684_c.jpgWP_20170624_10_21_40_Pro_zpsejxmrijt by jon sutherland, on Flickr
before and after...
https://farm5.staticflickr.com/4325/...e5f3b21c_c.jpgWP_20170624_10_27_17_Pro_zps8unrrmgc by jon sutherland, on Flickr
Hi Jonathan, looks like that sill could do with a little a little nudge to the rear ... And ref the bonnet rubber , were HUK particularly greedy with that one?
Hello Jonathan....inspired by your recent post (and, just for once, a task you detail which I can sensibly do myself!) I looked at the part no. in your photo - 71152-SL0-010.
From the diagram on the 'Acurapartswarehouse' site, whilst the part looks to be about right, the part description is Seal, FR. Bumper Plate Center which sounds less correct....are you are to shed any light please?
