They didn't bother to put these screw back in.
https://i.postimg.cc/Gt87TYjc/IMG-20190304-132521.jpg
Vband from Turbo to Exhaust is it tightened.
https://i.postimg.cc/VLtbFHf0/IMG-20190925-164144.jpg
Turbo inlet pipe only marginally Clipped in.
https://i.postimg.cc/3xH0fCNS/IMG-20190220-150624.jpg
Exhaust is badly installed, hence damage the Valance.
https://i.postimg.cc/t4rh7v91/IMG-20181227-113110.jpg
I'm very sad to see those shocking pics, esp. of the cam journals.
What are you going to do now? Throw the turbo out? A turbo system is only as good as its tuner is.
I went CTSC 10 years ago on an engine with nearly 90k miles and had some kind of feelings if I ever will regret it in the future. I did the install myself. FF: after 10 years and more than 40k miles the engine and CTSC are still going strong. All 6 still at 14.5 bar in a compression test. No troubles, no nightmares, just a few Gatorback belts, new fuels lines and an idler (plastic) pulley as preventative items. Not sure if the (non-OEM) cats needed to be replaced last year but not a nightmare.
Good luck with wherever you're heading to.
Well bang goes their reputation! I’m really sorry to hear you’ve had so many issues. There seems to be no ambiguity though; if they’d screwed up a couple of things it might have been forgivable. But they have shown a high consistency at sucking! I hope you get it all sorted out.
Cheers.
Really sorry to hear about this, he dosen't come across as being a "cow boy", I guess this is why you trusted him with your car in the first place.
IIRC you are not the only one in the "club" that has had this done, correct?
