Air Con Condenser Fans - Air Flow Direction
Hi All,
I've just rebuilt my air-con condenser assys, including replacing the fan motors with some non NSX parts (Honda Goldwing radiator motors). Although there are arrows on the NSX actual fan blade mouldings & I've wired the motors to rotate in this direction I'm dubious, now I've tested the assys, that they are rotating in the correct direction.
The reason for my doubt is, when the fans are in operation, they are blowing air through the condensers, i.e. from wheel side to bumper side.
As they have never worked since I've owned the car, I don't know if this is correct. I would have thought they would pull air through the condensers, so work in conjunction with the natural ram effect of air flow, when the car is being driven ?
Or do they only really ever switch on when the car is stationary, as the ram effect of air movement is sufficient to cool them, other than when the car is stationary ?
Cheers for any enlightenment.
Wix
