my aircon evaporator overhaul
In the continuing quest to narrow down the cause of the overnight condensation (and getting fed up with the prospect of scraping the ice off the outside and inside of the screen) I’ve moved onto the aircon evaporator.
I’ve checked/replaced the usual suspects, door membranes/door seals/frame seals, window adjustment, but to no avail! I experimented, and worked out that if I use the aircon during the day, when I go to it the next morning, the condensation is there, so it must be aircon matrix related. I’ve checked the heater drain tube wasn’t blocked, but I never get an aicon puddle under my car, never have! I’ve already sorted a cabin filter solution, but I’m guessing it’s the already accumulated crud that is giving me the issue (I hope!)
I sourced a replacement one a couple of weeks ago and this morning set to work! I started at 9.18 with what looks just like an NSX!
http://i301.photobucket.com/albums/n...930640x480.jpg
glovebox/underguard and central armrest out.. (9.30… can you tell I might have done this bit before!)
http://i301.photobucket.com/albums/n...931640x480.jpg
clock/vent/centre console out….(9.39!)
http://i301.photobucket.com/albums/n...932640x480.jpg
instruments and electronics out……(10.00)
http://i301.photobucket.com/albums/n...933640x480.jpg
