1997 RHD E-NA1 DBW AT JDM Cooling Hose Replacement - Required Parts
Hello together,
As a long time lurker in this forum and happy NSX owner since 2014 (when I was still living in Tokyo) my car is now registered in Germany and awaiting replacement of the cooling hoses.
After checking online (NSXCB, epc-data.com, jp-carparts.com) the following list of parts was created:
Part Number |
Amount |
English |
Notice |
19103-PR7-A00 |
1 |
HOSE, EXPANSION UPPER |
19104-PR7-A00 |
1 |
HOSE, EXPANSION LOWER |
19107-PR7-A00 |
1 |
TUBE, OVERFLOW |
19501-PR7-000 |
1 |
HOSE, FRONT WATER UPPER (YELLOW PAINT) |
19502-PR7-010 |
1 |
HOSE, FRONT WATER LOWER (YELLOW PAINT) |
19506-PR7-A01 |
1 |
HOSE, REAR WATER UPPER (WHITE PAINT) |
19507-PR7-A01 |
1 |
HOSE, REAR WATER LOWER (YELLOW PAINT) |
19518-PR7-A00 |
1 |
HOSE, WATER UPPER MIDDLE |
19519-PR7-A00 |
1 |
HOSE, WATER LOWER MIDDLE |
79721-SL0-010 |
1 |
HOSE A, WATER INLET |
79722-SL0-A00 |
1 |
HOSE, WATER INLET (HEATER) |
79725-SL0-A00 |
1 |
HOSE,WATER OUTLET (HEATER) |
79726-SL0-000 |
1 |
HOSE A, WATER JOINT |
79727-SL0-A00 |
1 |
HOSE A, REAR WATER OUTLET |
79728-SL0-A00 |
1 |
HOSE, WATER INLET (ENGINE) |
19422-PR7-A01 |
1 |
HOSE, OIL COOLER INLET |
19423-PR7-A00 |
1 |
HOSE A, OIL COOLER OUTLET |
19424-PR7-A00 |
1 |
HOSE B, OIL COOLER OUTLET |
19429-PR7-A10 |
1 |
HOSE,ATF COOLER INLET |
19430-PR7-A10 |
1 |
HOSE,ATF COOLER OUTLET |
19522-PR7-J02 |
1 |
HOSE A, BY-PASS |
Replacement part for 19522-PR7-J01 |
19524-PR7-A01 |
1 |
HOSE B, BY-PASS |
19526-PR7-A00 |
1 |
HOSE E, BY-PASS |
91318-PY3-000 |
1 |
PACKING OIL PUMP |
'8' sealing oil cooler |
19012-PD2-004 |
2 |
PACKING DRAIN (T.RAD) |
Radiator bleeding screw o-ring |
90471-580-000 |
2 |
PACKING 8MM |
Washer for center floor cooling pipe |
19045-PR7-J24 |
1 |
CAP COMP. (SHOWA ALUMINUM) |
19101-PR7-A02 |
1 |
TANK COMP., EXPANSION |
19301-P8E-A10 |
1 |
THERMOSTAT ASSY. (NIPPON THERMOSTAT) |
19511-PR7-A01 |
12 |
CLIP. WATER HOSE (40.7MM) |
19512-PC6-003 |
6 |
CLIP. HOSE 18.7MM |
19513-PE0-003 |
12 |
CLAMP, WATER HOSE (21.7MM) (CHUO SPRING) |
90661-SL0-A01 |
6 |
CLIP. HEATER HOSE 30MM |
95002-412-5004 |
8 |
CLAMP, TUBE (D12.5) |
95002-700-00 |
1 |
CLIP. TUBE (C11) |
08CLA-G02-6L0 |
1 |
4x 5L LONG LIFE COOLANT |
The first question would be: Is the list complete and matching the cooling system of a stock 1997 RHD E-NA1 DBW AT JDM NSX (VIN: 1400005)? - done, thanks Kaz -
Secondly, what would be the best option to buy the parts? Honda Germany is notoriously expensive (e.g. 250 Euro for a coolant tank). Some US parts-dealers are offering international shipping. I could aks one of my Japanese colleagues (it would be a bit of an effort for them and I would like to help them in a similar way, too). I also heard that KAZ is selling complete sets (?)
