NSX ABS Power Unit failure
I brought the car (NSX NA1) to make the diagnosis in a Honda workshop, because the ABS light comes on (ALB).
the car is not been used for 3 years
ABS Diagnosis says that the circuit does not go in pressure.
Possible causes include the failure of the ABS Power Unit, electric motor or oil pump failure or pressure accumulator also broken.
Replacement of pump and accumulator is quite expensive.
Does anyone know if you can disassemble and check the Power Unit, check electric motor and the pump, check the accumulator?
could it be a problem of air bleed after oil change, or the accumulator pressure switch failure?
is that system similar to other Honda models? Any advice?
thanks
