Headlight beam adjuster whirring
Hi
a few years ago my right side headlight beam adjuster appeared to be constantly trying to adjust itself, so I disconnected it from under the switch in the centre console. I recently reconnected it just to check it and it was doing the same thing, the left headlight beam adjusts correctly when I move the control knob.
What is the fix for this, is it just a new motor on the right hand side or something else, and is this the correct part number - 33129-sl0-a01 which as been superceeded by this one on later cars but someone on prime says it fits fine too - 33129-SL0-N11
Chris
