1 Attachment(s)
How to read the error code...
Probably, already being posted by other members and you can find similar info on NSX Prime but as many owners sent me similar question email on this topic, decided to share the procedure that I used in the reply.
I’ll try to update this over the time to cover most of the controllers as some of the procedures are different from others.
The most important thing:
Even if the Workshop Manual or someone asks you to do so, DO NOT reset the error code until you have read it.
On some of the controllers, disconnecting the battery or letting it below a certain voltage will result in resetting the error code so be careful.
First, please refer to the following pdf file for the basic instruction.
Attachment 9796
It is for the LHD model and also it is for the Engine MIL/CEL but you will get the idea.
For those with OBD-2 model, you can still use this procedure if you don’t have the DTC reader.
Most of the controllers use Long and Short blinks of warning light to show the error code.
However, the early ABS system (the one with the famous squeaking noise from the ABS pump and the sticky solenoids issue) will only show Short blinks with the ‘Main’ and ‘Sub’ code separated by 1sec pause/interval.
On some of the controllers, they have the ‘light bulb check mode’ at the very beginning of the process so be careful not to confuse it as part of the error code.
Most of the controllers will keep showing the error code until you turn the IGN switch OFF.
However, there are a few controllers that have a certain time out and thus, won’t repeat showing the code.
For these controllers, simply turn the IGN switch OFF and then ON again to start the new reading process.
The SCS Blue connector
[The photo may look different depending on the spec of your NSX but the Blue 2pin SCS connector is the same for any spec.]
The Blue 2pin SCS connector is located at the passenger foot well area.
At the factory, it is secured to the left top edge of the silver metal ‘kick-panel’ using the blank mating connector.
However, on many NSX, the SCS connector was not placed back in its original position after the diagnosis and tacked away somewhere else so you may need to search for it.
On later models (95+), you may have another blue 3pin connector next to the SCS 2pin one.
3pin one is for the data communication so please make sure to locate the 2pin one for the SCS purpose.
1. Not required but easier if you peel the passenger area carpet off.
2. The Blue 2pin SCS connector.
3. Just remove it from the blank mating connector.
4. Create short circuit by using the proper mating connector.
However, most of the owners are using just the paper clip instead….
If using the paper clip, please make sure to insert it from the back (WIRE side) and not to the terminal face/opening as it could damage the terminal itself.
5. Turn the IGN switch ON but do not start the engine and follow the procedure in the above pdf file.
