Hi Guys
Has anyone found a UK supplier (other than Honda UK) for the 3 small plastic panel clips that hold the rear bauklhead upper panel trim in place?
Honda part No. 91560-SL4-003 or possibly 91560-SM4-003 (1991 NA1)
Ta Gary
Hi Guys
Ta Gary
SM4-003 (superseded to SL4-003) has round end tip and because of the material used and the design, unless you perfectly align the end tip to the hole on the firewall, you will break the clip when pressing on it.
Instead, I normally use the SL0-T00 introduced on the later models.
It has sharp pin point end so that it's much easier to aim/feel for the hole at the firewall.
Because of it's shape/material, it's hard to break it.
Although it's for later model, I have no problem using it on earlier models as well.
Not cheap from HUK though and I don't know whether there is an aftermarket one available or not in this design.
By now, I think clips from recent Honda models should do the job so just browse through some of the aftermarket clip manufactures website and try something similar.
https://www.ebay.co.uk/itm/10x-Pilla...IAAOSw8w1X-19G
Are these the same or usable in the same context?
They do look almost identical. Let us know how they fit and if so, details please.
I'm sure some will claim the red ones add to your top speed.....
Actually, as it transpired, it was special red clips with BLACK TOPS that were the best fit ;-)
Attachment 13423
Unfortunately, these have now been discontinued but the plain red clips can be sourced from
https://www.ebay.co.uk/itm/391217719327
Gary
Thanks Gary... bought a set of ten from your link
And I have too, cheers.
are we allowed to put toyota bits on a honda? will they not react? ;)
Thanks Gary, I bought some too
think we all have!!!
I think I must have nearly every type of plastic clip made and only a very small number actually fit anything.:)
Has anyone found any to fit the left and right panels behind the seats at all?
I think they might be part no. 90668-SJ4-003
