Originally Posted by
Kaz-kzukNA1
I wrote the same thing here regarding the speed rating but whether the insurance company is aware of this fact, that's another story.
Just ask your insurance company and also ask them what happens if the owner installs winter tyre for snow driving.
This was raised to the insurance committee several years ago when we had lots of snow in one winter here in UK.
Speed rating is not as simple as just showing the capable max speed.
There is a reason why it's written together with the load index.
If you have ever visited the tyre manufacture's dyno, you will understand how the speed rating is tested.
The tyre is loaded at the level of load index weight and then the speed is increased at specified rate/time to achieve the max speed.
Speed rating is based on flat surface and load index of 91 and 95 are both over 600kg.
So, if you are driving on the flat road surface at high speed and if your loadcell is reading more than 600kg at each rear corners, you better check your chassis or open the boot to see what's in there.
On flatpatch with corner gauge, standard NSX will show about 350 - 450kg at each rear corner depending on the spec/side and you won't be able to generate enough downforce to achieve load index figure at each corners on flat surface even with the NSX-R aero package.
So, even with W rating of 270kph and unless you can magically generate well over 600kg corner weight at each rear tyres, you are fine. Again, if you are worried about the insurance, just ask them.
Based on your other posts, your NSX is likely to be NA1.
If you have ever tested the NA1 NSX out of the factory without any modifications on the proving ground, you will find it quite challenging to exceed 270kph without following wind.
The speedo on the dash is not accurate enough at this speed region so you need different equipment for this.
NSX is very sensitive to alignment change.
I used to spend more than 2Hrs for adjusting with the place I use.
As goldnsx suggested above, it's not the equipment but more of how the operator adjusts it.
Hope another owner in your area can recommend you a place.
Regarding the tyre, that tiny contact patch is what you are relying to turn/stop the well over 1,000kg metal mass energy under all sorts of conditions.
5mph is enough to throw your body forward if you hit solid wall.
Regardless of NSX or not, please select decent one.
For me, tyre is another engine on our NSX.
