https://lh4.googleusercontent.com/-w...0/IMG_0055.jpg
Interesting enough, I posted this photo in my blog yesterday morning.
By now, most of the NSX owners are aware of the common faults and weak points of our NSX but if you are a new owner within the last few years or thinking of buying one, then probably not familiar with these well known issues.
(By the way, swhatley82, if you are thinking of writing your own NSX build thread, you may want to change the subject title to represent your NSX.)
Since this is your 'Build' thread, I won’t go into too much detail but please replace the crank pulley at the time of
every TB service regardless of the annual mileage.
In Japan, it is a
must item to be replaced at the time of every TB service at
any NSX specialists.
The shape, design, feature are different between MT and AT model so it’s hard to tell when exactly it’s going to fail but you can do a quick check by looking at it from above as described in the following link.
Parts No. difference between the MT and AT are also included.
http://www.nsxcb.co.uk/showthread.ph...2032#post72032
The story behind the crank pulley and my view on the crank pulley shield.
http://www.nsxcb.co.uk/showthread.ph...4144#post74144
It's not just acting as the damper but also it's there to shift the resonance frequency for TB protection so while you can install the shield, it's best replacing it regularly and never allow it to fail.
As mentioned at the beginning, if you are a new owner or thinking of buying one, you may want to go through the items in my
NSX Technical and Service Information Index and the same information
Index No.2 that will cover major points of our NSX.
I ordered new one from Japan last week so at least it was in stock at that time.
For the removal/installation, it will require different locking tool between MT and AT spec.
Please make sure to treat the crank pulley bolt per the workshop manual on installation. Otherwise, it will seize and you will have big time when trying to loosen it next time.
It can be replaced at any time without touching the TB related parts so no need to open the engine.
Please replace two AUX belts (ACG & A/C) at the same time if these were not replaced at the time of last TB service or within the last several years.
I better stop now as it's getting too long for your build thread......
