Na I don't think so, you caould always have a note saying that with any car 15yrs + you can expect the odd wee thing wrong, and most of this list is fairly minor and can be repaired/corrected fairly easily/quickly.
at least the list doesn't have head gaskets (any K series rover!), con-rods trying to escape (common on M5 bmw), major electrical problems (anything italian!) and that sort of thing...
amazing what you find out when you have a friend who's a recovery driver!
Don't get to see much of your friend then Britlude !?!
SS;)
Kevin, I think we seem to have run out of minor common faults s I'll leave it to you to work your magic. Having had a look through, yeah there is maybe a few things on the list but it';s nothing that a little time and patience can't sort out, and nothing really bank-breaking either.
Rear glass hatch rubber surround works loose, noticeably along lower centre edge. Most noticeable when car exposed to long periods in the sun ... so probably not that common ;)
Apply silicone sealant and push back into position.
The problem above reminds me of another. The dasboard is prone to cracking near the light sensor. The dashboard then squeaks. It's more common in the sunnier parts of the States than here though.
The wheel well liners clips become brittle rendering any atempt to disassemble them destructive.
Bolts for the lip spoiler and the front number plate mounting plate, rust in place and require three hands to work loose without ripping the lower front balance.
Sun visors split open at the seams.
Before buying a new one (really £50 for a bit of rubber I ask you!) I experimented with stretching my one back to full length (ooh vicar!). It retracted back again after a few weeks and I repeated the process. It hasn't shrunk again so I dare say that if you simply pull it back to length a few times it might be ok? Failing that a small bit of adhesive or double sided tape at either end should stop it shrinking again for no cost.
Robin
when the final list is comiled, perhaps there could be list of DIY/ Dealer fixes at costs so that prospective owners can put all of this in perspective?
Stretching Rubber !! :cantlook::embarassed::laugh:
If you want some more then:
Horn buttons, a bit fraglie.
Euro Smile on the rear bumper. :)
OEM CD autochanger sticking.
