been a bit tardy with posts lately... so a quick bit of house keeping, as i seem to have a few straggly threads...
http://www.nsxcb.co.uk/showthread.ph...-gearbox-issue .... chasing a gearbox glitch that is related to throttle position sensor signal...... not resolved here....
http://www.nsxcb.co.uk/showthread.ph...-unstable-idle.... also an unstable idle issue which also includes an added bonus of an aerial change, and TPS change (which should be in here!)
and finally
http://www.nsxcb.co.uk/showthread.ph...eset-procedure 3 pages of unstable idle, associated investigation, blowing up of components and a resolution!!!!
upshot, lots of investigation, swapping of bits, swapping back, more testing, accidentally killing ecus, replacing ecus, and more tweaking and all is well! we have a gearbox behaving, an idle in the 750-800rpm area, and the exhaust is running far cleaner... so finally we can move on
at Beaulieu Supercars, it was noted by Sarah, that her leg was getting wet as we pulled into the show..... hmmm.... no coolant pipes around her, but put the heater on full and drips were spitting out of the lower heater vents...... hmmm....
pull the carpet mats up, and the carpet .... fortunately i had made new, finest green carpet, so its in sections, rather than a single moulding, so i quickly found the puddle of pure fresh water in the footwell.... a proper sloshy puddle! so unscrew the footwell vent cover and pull that bit of carpet out of the way, and lo, the heater box was dripping quite profusely! pull out the drain hose, and nothing, prod a twig up it and it starts to drip....
now i've only seen a AC wee puddle under my car about twice in the 14 years i've had it! so avoiding using the AC and on returning home pulled the carpet and under mat sound deadening, which does a really good 'sponge' impression and dried it all out over a few days.... wringing wet was the literal phrase!
putting a tiny camera up the drain tube hole showed a couple of bits of dead foam so a quick airline blow was used to clear it, and heater on full had airflow out of the drain tube.... but i still wanted to make sure...... so.....
start digging:
and a hole, with AC evap pipes close behind, so wise to go gently! the foam was cut with a scalpel.....
https://live.staticflickr.com/65535/...64fca0cf_c.jpgIMG_20190921_162332 by
jon sutherland, on Flickr
so now i have a viewing window, that i can investigate with my lil camera thing! (after finding out it wifi's to my phone, and sulks if it's near metal, so camera in car, control box and phone outside, just to be awkward!)
no doubt going in from the other side would be better, as the evap pipe loop isn't that side, but then you have to fight around pedals..... and cant get the carpet out of the way so easy.... and there'a a steering wheel in the way..... etc etc!!!
