another little aside from a couple of weeks ago was fitting a filter in the PCV to throttle body line.... we all know the inlet plenum/back of the throttle butterfly/air temp sensor are prone to get covered in a sticky oily mess, i decided to investigate fitting an oil separator to clean things up!
i looked at the general options on the internet and NSX specific ones on Prime, researched other solutions and options, and eventually ignored all i found in favour of a small compressor filter widget that was lying around at work. this fulfilled 2 criteria, 1. it was small, and 2. it was free!
all i had to buy was a couple of fittings and a bit of pipe! then make up a mounting bracket and fit it in!
i'll see how it goes, if it actually captures anything, and then paint it to help it blend in!
the kit of bits... the filter is 2 stage, with individual drains.
https://farm5.staticflickr.com/4291/...fc95a25b_c.jpgWP_20151212_11_51_41_Pro by jon sutherland, on Flickr
and fitted.... the original PCV/inlet pipe is used, just ending at a slightly different place!
https://farm5.staticflickr.com/4302/...238bf823_c.jpgWP_20151212_13_15_06_Pro by jon sutherland, on Flickr
https://farm5.staticflickr.com/4328/...0da41f8e_c.jpgWP_20151212_13_21_22_Pro by jon sutherland, on Flickr
we'll see what its collected after a while!
