Do Honda still do a 80327- SL0 condenser pipe suitable for a 1991 NSX which has been converted to run on R134a gas. If so, what is the part number?
Just quick reply as so much to do.
Despite several R12 and even the R134a spec pipes were already discontinued, the 80327- one is still available for both spec.
The R12 spec one is 80327-SL0-003.
As per message in the above photo, risk management required.
The pipe comes with one of the o-ring but most likely, it's the R12 spec.
Get aftermarket o-ring/seal kit and replace whatever fittings you are going to touch.
These days, aftermarket ones from reputable companies are compatible with both refrigerant.
Or, get the OEM R134a spec o-ring.
Thanks. Kaz.
is there a part number for the OEM R134a spec o-ring for 80327 ?
many thanks
Chris
