Hi Paul
I couldn't find anywhere stocking the AD08s in the 02+ rear size. Where did you get yours from?
Cheers, Rich.
Having read all the threads on tyres the choice for a full set on my 2001 NA2 will be AD08's rather than RE050A back and RE040 front - unless they wear out a lot quicker than the Bridgestones?
Next question is what the wear ratio on the AD08's on the back compared to the front? 2:1?
Don't want to get caught out mismatching front and back in the future due to tyres being discontinued/lack of availability and would rather order 2 sets of back tyres and 1 set of front tyres now?
in germany there is no problem to get them
http://www.reifen.com/de/TyreSize/Li...rFilterKey=127
maybe buy them at the ringfest time ;)
I'm currently running on Dunlop SP Sport 900's 214/40x17 fronts and 255/35x18 rears on Khan rims and was informed by the previous owner these were the same sizes as the NA2.....looking at Kev's initial post, this is incorrect: should be 45 profile on the front and 40 profile on the rear. Apart from giving a slightly incorrect speedo reading, would the lower profile affect the handling adversely?
My NSX seems to be handling fine in wet and dry conditions (took it for an amusing 11 lap spin at the Pau Historique a few weeks ago in the rain: more about that later).
The rears are now on the limit and I read that Conti 5's are excellent all rounders....has anyone had experience of these?
The front's still have 5/6 mm of tread....would I be mad to run these with new rears?
The usual tyre dilemma, advice appreciated!
Mathieu
Hi Mathieu,
Your 17/18 rims are not OEM anyway so difficult to advice on what the best combo....maybe worth posting on NSXPrime as the Yanks are more into 17/18 - 18/19 rims so would be able to advice more accurately.
Most UK NSX run on either 16/17 OEM or 17/17 OEM...hence 45-40 profile.
Your 17/18 will run a lower profile (40-35) to keep the outer diameter of your wheels as close to OEM to avoid TCS activation.
Just got my car MOT's and everything was Dandy, however i got an advisory on the front tyres.
Its a 97 Model and currently got
RE010 215/45 16 on the front
RE050 245/40 17 on the rear
By the looks of it you cant get the RE010 anymore, but the obvious replacement is the RE040, if someone could just confirm?
Also from what i've read the RE050 on the rear are run flats?
James
Alot of members here have used or still using BS REO40 for the fronts and rate them highly.
There are both non runflats and runflats REO50, the letter A after I think means runflats or is it the otherway round?
Can anyone confirm?
I run REO40,s front and 50's rear as the 17 x245 x40 REO40 no longer available in this size
The combination work well.
Isn't the REO50A an asymmetric tyre ?
