Anyone have some numbers?
All the figures were at the fly. The machine gave out those figures automatically. We weren't given any wheel figures.
That is a shame - it would be good to see the unadjusted numbers. The chaps at Surrey Rolling Road say that Power Engineering seem to adjust the flywheel figures by approx 20bhp more for Subarus - not sure how much the difference would be for 2WD.
My peak power was around 7300 rpm, with torque peak at 6500 - I plotted the numbers on my blog
http://www.noelwatson.com/blog/Perma...5d4560c45.aspx
It would appear that mine is another of the 3.2's that peak slightly higher than 6800, although I appreciate all rolling roads are different. It will be good to get on the TDI dyno in the New Year
Some other numbers I was given (at flywheel)
E46 M3 - 330 - no wonder they beat me at Bruntingthorpe
S2000 - 210
Civic Type R -197
Griff 500 - 270
Hi Noel,
Just got around to to looking at your power/gearing spreadsheet and graph. Interesting stuff.
Would you mind plotting a torque/gearing graph when you get some time?
The power/gear plot suggests it but one thing that the torque/gearing plot would certainly do is prove to any doubters, and there are always a few, that you MUST change up at the limiter if you want absolute maximum acceleration.
On the other thread you said that you were recording 160mph on the rev limiter at Bruntingthorpe? If so we may have the gearing figures slightly wrong. The table you refer to in the spreadsheet and I usually use from NSXPrime says 160mph at 8000rpm meaning we should be able to do 166mph at the 8300rpm limiter.
It's all somewhat acedemic but the pedant in me (oo-err Mrs) likes to know these things correctly :-)
Mark
Mark,
Will do the torque vs gearing in next few days. I would like to know what the limiter is. I think it is 8000 for a number of reasons
1). The dyno used 8000 for the limiter - if it were 8300 this would shift my peak power to around 7600 rpm - surely too high? (my torque peak was high at around 6300 assuming 8000 limit)
2). I have compared my GPS speed on limiter to these
http://www.nsxprime.com/FAQ/Technical/gearratios.htm
and they are spot on for 1st, 2nd and 5th (not tried the rest).
However, I'm more than happy to be proven wrong - how can we measure it?
Simon,
I guess that Charlie has had more than one S2000 on his road so it was an average. Dan said the S2000 had the same number at his rolling road.
http://nsxcb.co.uk/testvb/showthread.php?t=3958
Maybe it is the type of dyno?
Mark,
Thinking about this, I'm not sure what torque vs. gearing would show us as we would have to scale it by the gearing to get tractive force at the wheels - I think this is what my original graph showed - unless I am missing something? i.e. My car will be producing less torque at 7500rpm in 3rd at 95 than in 4th at 5800 rpm but will still be accelerating more quickly
Regards
Noel
