one of the guys on Prime is developing this - I have already expressed my interest, maybe some others are interested too
http://www.nsxprime.com/forums/showthread.php?t=40142
I think there is another thread where he says the high speed stability of the car is worse, as without a ducted bonnet the air from the radiator has nowhere to go.
It's also missing the front spoiler as well. For sort of thing to work properly, it would be lower at the front than at the back.
The ideal setup for your car Darren, would be a plate from the lowest front edge of your Wings West spoiler, gradually rising up back to the floor of the car.
The guy on prime doesn't fill me confidence that he has measured anything. His quote the 'brakes seem cooler, by seat of the pants feel', makes me laugh.
I agree, this design just looks alittle far fetched. The brake ducts are set too far back. the hosing used for the ducts is cheap flexi. The positioning of the brake ducts would seem air would not pass through the duct at the same rate it was entering. This would cause an air bubble effect.
But I aint no expert on aerodynamics so maiby im just talking sh** after a heavy drinking session last night. :roll:
Hi Guys
I pointed Al at this thread and he came back to me with some relevant feedback to the comments made here - I thought it would be valuable to post them here
Darren
Quote:
Originally Posted by ATERPAK
Al needs to read more carefully. My comment on measurements do not refer to measuring for fitment. I am refering to measuring actual brake temps, measuring downforce and measuring an improvement in lap times.Quote:
I also did not mention anything about NACA ducts. For info, I have plenty of books on racecar aerodynamics as well as suspension, braking and composite material text books. My comments are not based on speculation. Any other comments I made, were to suggest improvements on this design and make it more effective.
Attached pic is the NSX-R. You will see in the attached picture the black front tray has a 'bump'. This will create a high speed airflow area, which will create downforce. Also the parts of the tray to the front of the wheels raises up, these smooth the airflow leaving the underbody into the wheel well. The edges on the sides of the aluminium parts of the undertray are there to prevent air from the wheel well entering to the centre of the car, not the other way round as Al suggests.
It's a bit more involved than just a pure flat floor.
I would consider the most salient point raised in this discussion was the the 'ducted bonnet' mentioned by Kevin.
Undertrays are all well and good but without an alternative route for radiator air (wheel wells or bonnet) the benefits will be reduced and engine cooling may be affected.
By the way, did I mention I'm in the process of bodging one for my car...just as soon as I find my can opener.
Mo...and I am serious.
thanks for the input Kev and Mo - some very valid points made there, I can certainly see where the downsides of the flat floor design are.
apart from any other shortcomings I reckon the biggest factor to bear in mind is that to do anything like this without first installing a scooped bonnet has got to be a no no as Mo pointed out.
still like the NACA ducts though as a cool factor to have incorporated into the design.
Following Kevin's points and the attached pic, I am definately feeling that a design mimicking the oem one has got to be better, with the open area under the wheels and the front tray incorporating the bump and rise.
So if Al is sticking with his current design I guess I'll bow out
anyone up for making one up incorporating the best of both designs?
Kev?
Detlef?
Detlef is working on making direct copies of the NSX-R undertray.
Without a vented bonnet I wouldn't do anything yet, and I still have wings to make!
SoS have a GT500 bonnet which is working out at £650 at the moment. I wonder how much a group buy on those would be?
