A/C Fan(s).....should they be that noisy??
I can hear mine cutting in from inside the cabin...is that ok or not??
:dunno:
:dunno:
What's the AC fan and where is it? My blower fan is a bit rattly but I don't think that's what you are referring to! The compressor 'cuts in' but that's underneath the engine I think so you really shouldn't hear that!
No, like you say, the compressor is in the engine bay. The noise comes from the front, definitely the a/c fans as it stops if I shut down the a/c. I'm pretty sure that there is 2 fans, one each side of the car behind the front bumper in front of the wheels.
See Darren's pic here:
http://www.darrenferneyhough.com/ima...ting/007os.jpg
Just interested to know whether they are inherantly loud or I need new one(s)?
They don't sound sick, just loud and I'm sure they have got slightly louder recently. Although it could be that I've only just started using the a/c again....
Simon, I hope its not a problem with the air con fans, I don't think I've ever heard them from inside the cabin, but my hearing is not the best! Maybe if I switch the air con on over the weekend & listen carefully to find out how loud they are. Off the subject, are those the said SOS brake disc or have you not had a chance to fit them yet? :)
ya thats right 1 on both sides
may be u picked up some **** thats runnin around near the blades
give me a shout is u need 1 or 2 lol
thx amo
James
the picture is of my car, and the disks are Black Diamond - standard sized replacements but with grooves.
Simon, if your fans are knackered I think I might still have the ones in the pics kicking around somewhere - shout if you need them and I'll hunt in the attic.
Darren I'm currently hunting down a full new set of disc, where did you get these Black Diamonds from, are they a direct replacement for OEMs & do you remember the price? Mine is a 1999 3.2 with bigger rotors. Are the pads standard OEMs or Black Diamonds own? Sorry for the many Qs! Thanks
Hi Simon,
You are lucky that your condenser fans do not run the whole time -even with the climate control switched off. This despite the control board rebuild in Crawley & by Briank -in fact Brian says his do the same & he does not know why!
The fans are pretty noisey, you are welcome to listen to mine to compare volume-at my house or I am in Crawley every Monday evening always in the Honda,
John
James
the Black Diamonds I use are direct replacements so you can bolt straight on and use any oem sized pads
I got mine from MSW - links below
fronts - £170 delivered
rears - £190 delivered
for anyone with the earlier model (like me) also looking for these, here are the links:
fronts
rears
note, whilst the NA1 & NA2 versions are listed seperately with different product codes, the spec listed on the description is the same for all - 282mm x 28mm front & 282mm x 22mm rear - this may well just be a typo on the site and the product for the NA2 are in fact the bigger sizes (297f & 302r I think?), but I would call them and double check before ordering!
also, Dali does a full set of slotted disks for $440
