6 Attachment(s)
US Radio Head Unit (USDM 1991) - Repair
While working on the radio from France anther one via NSX prime from the USA came in. All inputs and functions were fine but the speaker output was intermittent and worked only for a few seconds before cutting in and out randomly. Since there was obvious damage by leaking capacitors, their replacement and taking care of the PCB was the first item on the list.
Attachment 14824 traces near E509
With the large capacitors removed, it became more obvious.
Attachment 14825no massive damage but on a good way to cause further problems.
In addition, the flex cable connector next to the CD port showed suspicious greenish marks, usually related to being contaminated, too.
Attachment 14826 that colour ain't supposed to be there
After removal of the flex cable it became rather obvious why there was intermittent sound. The pins were corroded up to a level where they potentially lost contact completely. This requires a new connector and a new cable before continuing any further. After removal of the connector, some pins measured a resistance of less than 200 kΩ against other pins - in an OK connector they should be >2 MΩ.
Attachment 14827not looking good
Since the whole area was contaminated, it required the usual treatment: Cleaning the PCB down to bare metal and strengthening the VIAs by soldering a thin wire through them - about 30 of them were reworked like that, including the capacitor area.
Attachment 14828that should be better
A first test run and and one cold solder point later the radio was working stable and the two remaining capacitors on the power PCB were replaced. Not much damage to traces there but the capacitors already started leaking, too.
Attachment 14829on the bench
The US PCB layout seems to be more robust against acid damage. The usual path of the capacitor liquid does not cross too many components and as there is no extra processor one the lower PCB, required for the RDS decoding on EU radios, that one can't be damaged either. Happy to have a more-or-less regular repair instead of the usual, more difficult cases.
