Clutch problem advice please
I took my NSX out for a run ( to a Porsche Club meeting!!), and unfortunately when I got in the car to go home, the clutch pedal went straight to the floor and I couldn’t engage any gears. A helpful enthusiast suggested that I pull the pedal up manually which I did, and by pressing it very gently I was able to engage the gears, just enough to get me home with only 2 gear changes on the way. If I pressed the pedal too hard, the clutch was lost and I would have to pull it up manually with my foot.
I am not a born mechanic, so the car is booked in to be sorted next week. ( the garage owner has his own NSX.)
Can someone make some suggestions as to what the problem is likely to be? The car has done 87000 miles and had a new clutch at 67000 miles. I can’t see any evidence of leaking fluid.
Any thoughts appreciated.
