Hi
My radio is working. I want to keep the look so an OEM-style NSX replacement stereo would be ideal. I want to bluetooth my music etc from iPhone.
Anyone got any ideas?
thanks
Hi
thanks
Have a look on NSXPRIME. There's a guy over there that mods OEM stereos with modern internals but retaining the original exterior..
thanks an american I believe. I was hoping the uk had such a guy. I have emailed the US for more info
Presuming that your OEM head unit and Bose speaker AMPs are all working fine, then you have several options.
http://www.nsxcb.co.uk/blog.php?1811...t&tag=pa11-hon
Many UK owners including myself are using USA Spec PA11-HON as the interface for the Apple device with the classic 30pin dock connector. You can control the device through your OEM head unit like you do with the OEM CD changer.
If you have lightening connector instead of the classic 30pin dock, then so far, the recommendation is to get only the official Apple conversion connector.
There has been some reports of iOS compatibility issues??? resulting in not being able to control the device through the head unit.
You will lose the ability to control the device through the head unit but you can connect Bluetooth I/F on the AUX input and play whatever you like through the OEM system.
More common in the era of streaming.
http://www.nsxcb.co.uk/entry.php?144...tooth-Receiver
There are some owners using the device from GROM.
I don’t have direct experience with it so please search here and also on NSX Prime for it.
Thanks Kaz
I have emailed Graham at Plans Performance to see what he might use.
