on the jaunt around wales i noticed a knock every now and then from the rear of the car.....
returning to england and the quality of the roads highlighted the issue once again, so a bit of investigation required...
grabbed the top of the wheel. gave it a good pull and there was a noise/movement, got a helper to hold the top ball joint thru the wheel, did it again, and there was a little movement, so wheel off, suspension jacked up, big screw driver as a lever, and we have this...
https://flic.kr/p/2oSgmvs
(not a great vid, but it's awkward levering suspension and holding the camera! but you get the idea) (edit... goddam vid won't link/imbed grrrr)
so as an interim measure, i did an non honda approved mod.... tho i'm sure they use to do it!
off to the local motorist shop, spend £1 on parts, return, wheels off, drill a hole, tap, screw in said purchase, and sorted!
blurry pic
https://live.staticflickr.com/65535/...b9d81784_c.jpgIMG_20230728_115110 by JON SUTH, on Flickr
close up, in focus!
https://live.staticflickr.com/65535/...f708630d_c.jpgIMG_20230728_115117 by JON SUTH, on Flickr
did the other side , cos i had the grease nipple
https://live.staticflickr.com/65535/...224fcaea_c.jpgIMG_20230728_120536 by JON SUTH, on Flickr
in ye olden days, every ball joint had a grease nipple, then suddenly , when manufacturers decided they were 'sealed for life', they disappeared, to be replaced with the extra expense of replacing what could be a serviceable item... now it's serviceable, and will do until i source replacements...
yes, i know the rubber boots are very tired, i have replacements, but that will have to wait until after the car shows! especially with the associated risk when trying to split the ball joints!
