10 Attachment(s)
EU Radio Head Unit (EUDM 1991) - Repair
Another radio with intermittent sound output arrived at my desk. It was previously repaired in 2008 but not exactly in top quality.
Attachment 14896state of repairs 2008
Nevertheless it played fine for 5-20 minutes when it suddenly dropped silent. Different from a previous case regarding a USDM radio the main flex cable connectors where still looking good, so it had to be something different.
Attachment 14893trouble shooting
As soon as the audio went out, the voltage at the two main output amplifiers was checked and suspiciously low (3.9 V, should be ~10 V). This 10 V supply is generated by the Zener diode ZD807 but measured fine at the diode. As always in such cases, it's best to work backwards. After a bit of tracking and tracing, it became obvious that the 10 supply was fine but somehow did not reach the amplifiers that depend on it.
The reason was quite simple: A broken trace caused a disconnection on the way. After confirming it on an old board and adding a repair wire, the sound came back and was working stable again.
Attachment 14894an additional (yellow) repair wire
Besides the repair, the power supply PCB had its leaking capacitors exchanged, the volume knob fastened and a flex cable replaced that didn't look very good any more:
Attachment 14895leaking capacitors on the power PCB
Attachment 14897a fixed knob
Attachment 14898a damaged flex cable
Attachment 14899
BTW, the really interesting part was that the radio had been to a professional repair shop before and couldn't be fixed. They stated:
"The unit was carefully disassembled and and each part checked according to schematics. It needs to be retuned in an unrepaired state. The audio processor was checked and considered defective. After a long search we found out that it's no longer available."
This raises a lot of questions since the NSX radio doesn't have an audio processor and schematics haven't surfaced anywhere yet. In addition, everything that could be considered a processor in this radio is Alpine proprietary and was never freely available. My guess is, they opened it, couldn't find the issue and simply returned it charging their standard fee ..
PS: Circuit information regarding the 10 V supply has been added to the Radio Repair III page.
