7 Attachment(s)
Speaker Amplifer - Repair and Capacitor Replacement
One more French NSX owner had issues with his original speakers - which led him to turn the active speakers into passive ones, using a separate amplifier a few years ago.
he removed amplifiers have been waiting for a capacitor replacement and repair since then. The assumption that the PCBs were "in good condition" did not come true, though, especially since these are the first generation ones, easily detectable by the green electrolytic capacitors.
The right amplifier's PCB was showing a burned-out MOS-FET transistor as it happens quite often in case of capacitor leakage. The effect is described in the corresponding blog entry about technical issues with this design.
The centre amplifier board was suffering from so much capacitor leakage the the liquid was literally dripping from one of the transistors and the left amp PCB looked "normal".
Due to the obvious damage, no try was made to power any of them up before the PCB was cleaned, repaired and damaged parts replaced. The hot glue was removed by help of hair dryer, then all electrolytic capacitors, the MOS-FET transistors and the coils (for better access during cleaning).
Since one transistor was burned and all the others showed inconsistent readings, all twelve were replaced. They were either damaged or their case soaked up some of the capacitor liquid causing them to act strangely. Since a compatible replacement type is cheaply available it's the safer road to take.
One PCB was missing a small glass body SMD diode, probably damaged at some point in time, and the left PCB's C25's solder points needed strengthening as the acid had eaten away parts of the copper trace. The PCBs were thoroughly cleaned, all contaminated silk screen removed with a fibre glass brush and strengthened with an extra layer of solder before re-population and restoring of the conformal coating.
All went smoothly until the last amplifier. It did not make any sound when connected to power. This is a typical sign of one of the proprietary BOSE IC being damaged. Further analysis of U2 showed that it was providing the expected triangle signal on C16 but no high frequency output towards the MOS FETs.
Removing U2 by de-soldering is a difficult task. The old solder can't be sucked away efficiently, hot air can't be used due to the SMD components on the back of the board and a total number of 20 feet makes it impossible to mechanically move it while heating up leg-by-leg. A proven way is to cut off the legs and de-solder the remaining pins separately, which is what I decided to do.
U2 replacements were bought some time ago from a Chinese seller. These are salvaged parts since the where never available outside of BOSE but are genuine components, nevertheless. U2 was replaced with 20 pin precision IC socket and after putting in a replacement IC, the amplifier started to play again. We've been lucky U1 was not affected since the ICs used on these earlier PCB have not been spotted anywhere fore sale, yet.
Even though U2 was carefully removed, one trace needed to be repaired with a piece of solid copper wire.
Happy to report that a complete set of amplifiers could be repaired and brought back to working condition :)
