Eng Refresh Stage 2 – 10
, 23-12-2012 at 10:37 PM (2960 Views)
TB installed and once again,
time to check and check and check the cam timing.
TDC marker for #1 piston at the crank.
Front bank cam timing.
Rear bank cam timing.
TB installed and tensioned but
I’m bit too tired so decided not to
carry out the 4Hr marathon
valve clearance adjustment today.
To be 200% sure,
will double check the cam timng and tension again
before adjusting the valve clearance.
