Eng Refresh Stage 1 + LMA 15
, 07-09-2012 at 12:12 PM (3337 Views)
Super busy as usual and addition to other projects,
my boss is now in Japan until early November so
I need to look after the house as well which makes it even
harder to find my spare time….
Not much to report while replacing all of the coolant hoses……
Three hoses at the centre floor panel replaced.
New aluminium gaskets installed at the two draining plugs.
Another question mark on the build quality of NSX parts these days......
This time, the coolant hose at the lower radiator side had extra rubber moulded.
It didn’t cause any issues so I just used it but since the production of NSX stopped,
we started to see lots of quality issues with the NSX parts.
For example, the accuracy of some of the transmission parts, head light beam adjuster,
coolant hoses, latest ABS modulator, etc.
All of the hoses at the front compartment replaced.
Several pipe corrosion were observed but
not too bad compared to the ones at the engine bay.
So, all of the coolant hoses are now replaced.
As mentioned many times, radiator is a consumable.
This one is showing sign of slow leakage.
Should be fine for a while but at some point, please replace it.
Already several owners experienced sudden crack/leakage especially at the
right lower coolant hose neck at the radiator.
The heavily corroded CAT stud bolts.
As the flange section was also heavily corroded and even getting thin,
I was too scared to use excessive heat or punching them out as
I could bend or break the flange.
So, decided to cut them off using the metal cutting disc and slowly drilling them out.
One down, two to go.
Hope I can put the engine back in place over the weekend.
