Header tank, windshield lower molding
, 06-02-2011 at 11:15 PM (2324 Views)
Good call to replace the header tank. It was already cracked and leaking the coolant.
The coolant hoses were also didn't feel healthy so at the time of TB/WP service, it would be best to replace all of them.
You can replace the header tank without loosing too much coolant but I always bleed the air afterwards any way as a precaution.
The windshield lower molding.
Happy with the result after replacing the yellow clips.
As I had to remove the wiper arms briefly, sprayed some water and operated the wipers to check that they were installed properly.
Ready to return this NSX to the owner.
