ABS Error code #13 Part 2 ...
, 03-02-2011 at 11:07 PM (2955 Views)
Managed to find some time today to work on my NSX so started to investigate the cause of ABS warning light.
Popped out the FL sensor connector and after measuring the resistance, it confirmed that it was the sensor issue and not the wiring between the sensor and the ABS controller.
Going to place an order for another FL sensor… It was about 3weeks lead time so will be running my NSX with that annoying yellow ABS light for a while.
Joy of using 17 years old classic car as a daily driver....
