Goodridge Custom Made Brake Line – Black version
by , 10-06-2012 at 11:45 AM (880 Views)
Last year, I introduced the Goodridge custom made brake line for our NSX with OEM calliper/suspension setup as seen in this Blog Goodridge Custom Made Brake Line .
The original one had the clear finish so that we can see-through the braided stainless mesh.
One owner wanted to have it in Black finish and now Goodridge has kindly provided us with the new part no. as ZZMT-NSX-BK.![]()
I have already included the following info into the above original post.
The spec of ZZMT-NSX-BK is exactly the same (length, stainless fitting, number of line locator, etc) as the clear version of ZZMT-NSX except it has the black finish.
As same as the ZZMT-NSX, this black version is very flexible and not like the ones you will get from other sources.
ZZMT-NSX-BK
* 1 set to cover all four corners (FL, FR, RL, RR)
* Stainless fittings used and not the standard Zinc plated one.
* TWO line locators on EACH FRONT lines.
* One line locator on each Rear lines.
* Front Hose cut length WITHOUT the fittings: 550mm
* Rear Hose cut length WITHOUT the fittings: 470mm
* Black cover used.
It will cost just about GBP5.00 extra compared to the standard Clear version and the total cost for ZZMT-NSX-BK is GBP94.20 inc. delivery and VAT at the time of writing.
So, if you are thinking of replacing your old OEM brake hose, you have another option from now on.
Once again, thank you to Goodridge for their continuous support for our UK based NSX.
Email Blog Entry
